How can I find the original key for a project?
Rob Horan
September 30, 2021
Assume I'm on either server or datacenter.
There is a project whose key is XYZ.  The key wasn't always XYZ, it was something else in the past.  When?  I don't know.  Sometime.
I want to find the original project key.  How can I do it?
Mohamed Benziane
September 30, 2021
You should be able to retrieve data you want with this api call
rest/api/2/project/<project key>?expand=projectKeys
Take a look at the "Note for developers" section here
https://confluence.atlassian.com/adminjiraserver/editing-a-project-key-938847080.html
Kian Stack Mumo Systems
September 30, 2021
I would look in the project_key table. Find the current project key using the select statement
select * from project_key where project_key = '<PROJECT_KEY>';
After you've found the project id, find all the keys associated with that project id by using the query
select * from project_key where project_id = '<project_id>'.
In theory, the project key with the lowest ID number should be the original project key for your project.
VVor January 19, 2022
String proj_key = issue.getProjectObject().getOriginalKey()
I use this piece of code to find original attachments directory
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
