How can I get the project key?
Alexis Evans
I am using Groovy in Scriptrunner. I've imported com.atlassian.jira.project.Project and I need to get the project key of the current project in a validator script. What would be the correct way to do this?
Craig Nodwell
Hi @Alexis Evans
def issueproject = issue.getProjectObject().name
return issueproject
this will return the project name for the issue.
So in reality.
I'm not even sure if you need to import com.atlassian.jira.project.Project or if all you need is
import com.atlassian.jira.issue.IssueManager
I pulled the value out of my console without the project.Project call
Alexis Evans
Thanks so much, this seemed to work!
Like • Craig Nodwell likes this
Craig Nodwell
Yay
LOL
