How can I hide attached images in tickets from the general view of columns in a sprint board
Nada Farhat
February 11, 2022
Given I'm in a sprint, and in one column, I have multiple tickets where each ticket contains an attached image, how can I hide the images from the overview in the column these tickets are in? and only see the image when we click on a ticket?
Tyler Graf
October 25, 2024
- Land yourself to "Board" page of any project
- Click on "..." button at top right corner
- Select "Configure Board"
- Click on "Card cover images" at left side under "Board" section
- Toggle the "Card cover images" to enable or disable it
- Click on either "Back to project" or "Go to board view" to confirm changed behavior for with or without image attached to the ticket under the column
Jibran Bisharat
July 26, 2022
Hello. This answer works. Thank you. However, is there a global setting so that I don't have to do this with every upload?
carlosughini
Hi Nada,
This is quite easy and fast to solve!
The image itself inside the card had a three-dot menu with a "Hide on card" option.
You can click on the ... and then on Hide on card.
By doing this you won't see the image preview on the cards.
Please give it a try and let me know how it goes.
Carlos
