How can I insert a hyperlink in the Comment field of a Jira issue?
Wanda L. Lugo
I want t add hyperlinks to the Comment field.  How do i go about doing this?
10 votes
AnnWorley
June 15, 2017
Please see Text Formatting Notation Help
Here is the way to add a link:
[Link Text|URL]
Wanda L. Lugo
Thank you :)   Would this work for a document that is not online and simply saved on your hard drive?
Wanda L. Lugo
This style of hyperlinking works on web url's only.  I need to add a hyperlink for a word document that is saved on my shared drive.  How do i do this?
Like # people like this
Lavanya Yelluripati
May 29, 2019
Thank you so much
Deleted user August 30, 2019
Adding links is not working in Jira 7.6.4, none of the methods described on this page work
Like Tim Muller likes this
Sumit Deshmukh
September 12, 2019
Does not work for me on Jira v7.12.1
thonglv1989
November 13, 2023
Not working
Norman
June 17, 2024
This does not work.  I have the same formatting as indicated by Ann, but Upon clicking Save when editing a comment or Add when making a new one, it shows [Link Text|URL] instead of an actual hyperlink.
Matthew Warren
I had link names that contained |(pipe) which caused links to not render as clickable text. Replacing |(pipe) with -(dash) fixed my issue.
appit6791
November 11, 2019
I want to add hyperlink on particular text to comment forum. When i selected text and tap on link icon, it will show [Selected text](Link URL). How do i add hyperlink?
Zulqarnain Ikram September 19, 2024
[Text](url)
Above mentioned format worked for me in jira cloud
Hà Nguyễn Phương
July 23, 2024
I use format [text|link url]
-> Text is the link's name which you what to appeare
Wanda L. Lugo
mistake i wanted to reply instead of post an answer
