How can I integrate Jira with Galen
Dipika dhingra June 9, 2015
i want to manage and trigger test case execution from Jira
and generate reports based on results
AllanFox- BR January 16, 2019
Good Afternoon !
Helo, did you manage to integrate ?
Nic Brough -Adaptavist-
June 9, 2015
Probably by using the REST interface.
I think you need to define what you mean by "integrate" - define what you expect to happen with the two applications.
i want to manage and trigger test case execution from Jira and generate reports based on results
