Hello @anasuya
I believe this can be achieved by using the Tableau Connector plugin :
Hope this helps,
JT
The video has no audio, you are right, it is a step by step of how to setup their connector between JIRA and Tableau.
You can also access their documentation here :
https://www.aioreports.com/aio-app/main/public/aiotableauhelp
If you have any issue for the setup after installing the plugin, I am sure their internal support team will be happy to help you.
Here is the link to their help desk :
https://aioreports.freshdesk.com/support/home
You can also contact them at the following email : support@aioreports.com
Here is the updated documentation link:
https://aioreports.atlassian.net/wiki/spaces/ATCFJ/overview
In case of any questions / issues, please email us at support@aioreports.com
Regards
AIO Support
Hi @anasuya ,
There are many plugins available online for the solution.
For using any third party connector or using any in-house connector you have to keep in mind the points mentioned in the below article, mainly the authentication and performance part!
https://help.tableau.com/current/server/en-us/datasource_wdc.htm
You can also create one!
https://help.tableau.com/current/pro/desktop/en-us/examples_web_data_connector.htm
Hello, @anasuya
Our team has developed Jira add-on that allows you to export all your data from Jira to Tableau https://marketplace.atlassian.com/apps/1221376/tableau-connector-for-jira?hosting=server&tab=overview We tried to make the connector to be as easy to use as possible, but at the same time you may configure each Data Source filtering projects, issues, statuses, etc. We will be happy to help you with installation and other issues.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
