How can I keep Jira Estimates in Hours instead of Jira converting to Days and Weeks
Robert Andrzejewski
March 29, 2012
The reports, when exporting to Excel keep the Days / Weeks. Which make it difficult to do some analysis and costing based on any of the time fields in Jira. I would like to standardize on the hours format.
8 votes
Bryan Choate
In the Admin console, go to System -> Issue Features, and then select "Time Tracking" on the left. The full documentation can be found here: http://confluence.atlassian.com/display/JIRA/Configuring+Time+Tracking
Robert Andrzejewski
March 29, 2012
Perfect, thank you!
Michael O'Callaghan
Spot on. Thanks.
Al
New path
Jira settings > Issues > Time Tracking
Like • 2 people like this
Josh Sommers
This does not work. The time is still displayed in a variety of formats.
Examples of time display with this setting set:
  • 41.25h
  • 3h 40m
  • 38m
This is terribly inconsistent. Who would want a different format type on every line of a report? Does Atlassian intentionally make this stuff useless so that we're forced to purchase time tracking plugins?
Like • 4 people like this
Josh Sommers
Yeah, it's absolutely terrible. Atlassian really does not care about their customers or users or about making their software viable in a business environment. Their only answer is for us to buy another plugin that might do it better than JIRA does.
Srecko Anzic
I'm having the same problem. I have "Time display format" set to "Hours", and yet Jira Cloud displays tracked time in a mix of minutes, hours, and days.
This is a bug.!
It is affecting TIME ESTIMATE and TIME TRACKING fields!
Jon Karnofsky
I'm seeing the same issue.
Srecko Anzic
It is a bug, please vote\report here https://jira.atlassian.com/browse/JRACLOUD-69369
Kelly Nezwek April 9, 2019
That bug link seems to be for a different time tracking issue, one regarding the desire to just hit "enter" without needing to input an "h" for hour (etc.).
Is there a bug for the issue of time coming through as hours in some places, and as h/d/m in other places, when "Hours" is selected as the default display format that anyone knows of?
Like • Andrew Cave likes this
Nina - Phan Thanh Noi
November 20, 2019
I want to export time spent in BigGantt and the number of day/ week made me exhausted to manually convert them into hours or minutes. This is a UGLY bug of JIRA
Don Hamp
September 22, 2020
Does anyone have a solution from the Excel side.   I have a Confluence Pivot of JIRA data which is fixed in the y,w,d,m format that was shared here.    I copy and paste this data to Excel and am looking for an excel formula  that would convert 1y, 2w, 1d, 10m to  the correct # of work days.
7 votes
Mike Walters
September 19, 2019
If anyone is still struggling with this in Jira Cloud, try setting your HOURS PER DAY == 999 and DAYS PER WEEK == 999. This worked for us:
scott.fawcett
You don't need to change the Working Hours per day or Working days per week.  Just change the Time display format.  At least that worked for me...but the only place I'm interested in seeing hours only is on the Active Sprint board, so now I see all Remaining Estimates on the cards as hours only...which is exactly what I was hoping to see.
Tom
January 19, 2020
This works for me too. I changed it to 9999 on hours per week and working days per week and now time is displayed in hours instead of days... Thx Mike Walters
Like • Peter Riise likes this
Kevin Benson February 6, 2020
Mike,
You rock.
Kevin
Kelli Frattini-Adams
Thanks Scott.fawcett,, Exactly what I was looking for!
Laura Jakimonyte
June 12, 2020
ahhhh, finally a solution to this irritating problem. Worked perfectly for me. Thank you!
Rhuan Barreto
Perfect!!! Definitely the solution!!!
Smeet J Thakkar
February 4, 2021
Thanks, this worked like a charm.
Scott March 22, 2021
This is not a solution as it renders tempo completely useless for timesheet management
Mike Walters
March 23, 2021
While the solution i offered above (https://community.atlassian.com/t5/Jira-questions/Re-How-can-I-keep-Jira-Estimates-in-Hours-instead-of-Jir/qaq-p/1183352/comment-id/376424#M376424) has worked for us and others ...
@Scott is correct, If you use Tempo it will do wonky things like this --
We use Prime Timesheet instead and it doesn't seem to have any issues - https://marketplace.atlassian.com/apps/294/timesheet-reports-and-gadgets?hosting=cloud&tab=overview
Shame on Atlassian for not just fixing this nearly 3 year old problem - https://jira.atlassian.com/browse/JRACLOUD-69810
Liene
If You set up Workload and Holidays setup in Tempo setup, then it still gives You right amount of Hours for each person.
fonda
Srecko Anzic
It is a bug, please vote report here https://jira.atlassian.com/browse/JRACLOUD-69369
Deleted user April 10, 2019
I'm having a nightmare trying to set estimates to display as hours.
I repeatedly have done this:
Administration > Issue Features > Time Tracking > Time Format - Set this to Hours then all will be displayed as hours only
It seemed to work... briefly, and I could see estimates in hours. Only, the next time I checked it was back to displaying in days, hours, etc. Then when I went back into the settings, the settings had "changed" themselves back to display in "pretty...", i changed again and went to a project to look at the times and they were still in weeks. The settings seem to change themselves back. Or even if they don't, the times are still displaying in weeks.
What gives?
Can anyone help?
Kelly Nezwek April 10, 2019
I can't help, but we are having the same issue!  We're on the cloud version.  It looks like it does change estimates to hours on certain things (the Burndown Chart being one of them), but on actual issues it's still displaying in the "pretty" format.
I hope someone is working on a fix for this!
rukshan
July 7, 2019
There is surely a bug in the settings display section. Before you click on the 'Edit Global Settings' button at (...Issue Features > Time Tracking), it displays the 'hours' settings as to how I changed it before.
But when I click to edit it, it displays the default settings (which is "pretty") as the settings there. Which ideally should be the settings which I have set up, but not the default settings.
Other than that, the above setting change seems to be working now.
lrobertson39
March 29, 2012
Josh Sommers
Sometimes it will display as decimal hours, sometimes it will display as hours and minutes within the same search. Totally inconsistent and complete garbage. Can't even use a calculator to add time up manually. And then if you export it to excel, it's all milliseconds.
Srecko Anzic
It is a bug, please vote report here jira.atlassian.com/browse/JRACLOUD-69369
Like • 3 people like this
sandra whitmore
April 4, 2019
Please fix this. How can we manage the work hours with it this way. Critical management tool for EVM or just knowing how your project tasks are doing.
Sandra
Nacho Visedo
April 21, 2019
Yesenia pelos Fox this!
Its terrible
lrobertson39
March 29, 2012
Josh Sommers
Does not work. Still displays values in a variety of formats.
Lukáš Černý January 25, 2019
me for me in tempo
Josh Sommers
Sometimes it displays as decimal hours and sometimes it displays as hours and minutes, within the same search. So one ticket shows an estimate of 16.25 hours, and another shows an estimate as 8h 35m. In what world is that even REMOTELY helpful? Complete garbage!
