Using JIRA 6. Just downloaded and installed this week. Bug details and functionality is disabled using IE 10, although Chrome and Opera work just fine. Going into bug details shows empty frames. Most folk in my workplace use IE 10. Any idea what I can do here?
Have you checked that you have disabled compatibility mode?
JIRA does not work with compatibility mode, you will need to turn it off to get the page working.
Hope this helps, cheers :)
