Sign up Log in
How can I query the history of an issue?
Robert Matthews
We need to run a query to capture the transition state change (in the middle of a workflow) from the History within individual issues. We are running Jira 4.3.4.
rishiranka_bitbucket August 23, 2012
List Li = ComponentManager.getInstance().getChangeHistoryManager().getAllChangeItems(issue);
Where issue is the issue object which you can retrieve it from issue Key
Robert Matthews
I do not have access to the database. These queries need to be run within the Jira application and by a number of different people. The needed query must run against multiple projects as well.
Jobin Kuruvilla [Adaptavist]
August 23, 2012
From JIRA 4.4, there is WAS and CHANGED operators you can use. Nothing in 4.3.4 AFAIK.
Upcoming Jira Events
