I have dashboards that I've created that I'd like to put more fine-tuned restrictions in terms of views, probably at the project role level. However, I can't seem to select my custom roles from the share dropdown. I can only see the three default roles - admin, dev, and user. I'm assuming there's a permission flag somewhere that I'm missing, but I just can't seem to find it. Any help would be appreciated.
Hi Ryan,
After reading through the dexription, most probably this cause by the membership of the user in that role. Please bear in mind that you only can share a dashboard to a role that your user has a membership in it. For example if User A want to share dashboard to Custom role, User A must be a member of Custom role.
Hope it helps.
Josua
Hey Josua,
This does seem to have fixed the issue - I do find it odd though that as an administrator in the system I'd have to add myself to a specific role within a project (in this case, clients) to share dashboards with them, particularly when this isn't the case for default roles. Whatever works, I guess. Thanks for your help.
- Ryan
In addition (cause I just found this via search and it didn't clarify my question completely): If you choose the option "all" then every user and group that has a role in this project gets the dashboard - or filter, where the same menu can be found - even if you don't see the role in the dropdown.
Register now
