I use an issue type and its sub tasks. When an issue creates, the sub tasks creates automatically. I used Script Plugin (Script Runner). I want if one subtask resolved an linked issue create. Built-in script done this. I am searching an Additional issue actions codes to take parent issue summary.
sample code:
issue.summary = transientVars.getparentissue.summary + " - XXX"
is not working. How can I take parent issue summary?
log.warn transientVars
The issue you are searching for is in there. It might be called originalIssue or something, or try issue.
This question has been answered before, if you look around you will find the answer.
