How can I update a custom field value automatically for a Sub-Task by pulling value from parent?
Chris Lovvorn October 13, 2017
Our teams create user stories (issue type) and sub task(issue type). I have a custom field to identify the team that will be working. When a user creates a sub-task, I want the team field to update automatically pulling the value from the user story (parent issue)
Peter DeWitt
@Chris Lovvorn, Take a look at Jira Misc Workflow Extensions.  Almost a required add-on for Jira installs.  It can handle this and much more.
https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions/cloud/overview
pd
Ethan Foulkes
Hi Chris,
You can do this using the Power Scripts add-on.
There is a video tutorial walking you through your exact request in detail along with the code here.
Hope you can make it work!
Register now
