How can I use parent values of a Cascading Select field in a chart?
Michael I.
I want to group issues on a Pie Chart by parent value of a Cascading Select custom field, but I can`t find it as an option in the "Statistic type" select list. Could you please help me to find a some way to do this?
Michael I.
Using cascading select lists in default JIRA gadgets is impossible now (JIRA 5.0.2)
tester qa
September 11, 2012
I found an option and is this, when you create a custom field, this one have a label (Labels
Add arbitrary labels to issues.), so you can see the field in the dropdownlist of statistic type of your pie chart.
test.tech.001@gmail.com
Register today
