Sign up Log in
How can a time entry be corrected after entering it?
Jérémy Hamel November 29, 2018
Tyler Brown
November 29, 2018
Hey Jeremy,
If you are using JIRA's  native time tracking all you will need is the "Edit All Work Logs" permissions.  Then on the issue at the bottom under the "Work Log" section you should be able to edit any of the work logs entered.
If you are looking for the individual to edit their own work log they will need the "Edit Own Work Log" permission and then follow the same steps as above.
Hope this helps,
Tyler
