How can i Retrieve Deleted Custom fields in JIRA ?
Jira Atlassian August 6, 2019
Some one Accidentally deleted A custom field which was used in several filters. Is there a way to retrieve it back ?
Sid
August 6, 2019
The only way to retrieve a deleted custom field is to restore your Jira form a backup.
Jira Atlassian August 6, 2019 edited
Thanks !! Can you please guide me through the process ?
Thanks ! Can you please help me with how to do that ?
Sid
August 7, 2019
Joe Pitt
@Jira Atlassian @Sid didn't mention in their reply that restoring from a backup will OVER WRITE the current database.
Sid
August 7, 2019
Yes that's correct. It will overwrite the data.
Apoorva Tiwari
August 4, 2020
while restoring from backup , i am getting below error.
Can you help me how to do that.
Sid
September 11, 2020
can you check if the file exist in that location. make sure you give same name and extension
Register now
