How can i Send Comment via email
Ma Hao
My JIRA is 6.1.5,
I need a feature to send my comment to other via email.
I suppose the email could be sent by JIRA and mail message format should be as same as the notification mail message.
The send button could be located beside the comment which added by myself.
Is there any guide to develop such plugin?
Randall Robertson
January 3, 2014
JIRA does have a Share button on every issue. So, you could copy the comment in question, click the share button, type the intended email address and paste the comment in. That sends a JIRA email with the link to the JIRA issue as well as the comment you pasted in. Obviously that is more work in the moment than a dedicated email button on each comment, but it does not require any additional setup or maintenance, either. It also allows you to modify the comment or add additional notes if necessary, whereas a dedicated email button might not allow you to customize the message being sent.
Ma Hao
Thanks so much to remind me about the share.
I suppose we can use "@xxx" to share the comment to some one.
For example, @Jerry, this comment is useful.
Then Jerry will recieve the comment.
Sames like the users out of JIRA will be excluded.
But also we can use JEMH to do that like Andy's proposal.
Thanks for all of you
Felix Obes
January 14, 2020
It would be nice having the easy access to the permalink on the ticket as well as a dedicated ticket email address, like what Wrike has.
Andy Brook [Plugin People]
January 2, 2014
Well, on the one hand, the button click thing could be done with JETI, AFAIK its a one shot send, does what you ask, but what about inclusion for further notifications?
If you have someone outside of the JIRA environment, automated user notification is possible with JEMH by just typing their email address into a text custom field. Once 'added', any further issue change can result in a notification, but JEMH allows you to select only the specific events you want (eg ISSUE_COMMENTED) these non-JIRA users to be notified with, you can keep the default content or customize it. JEMH has yet to add a similar button, likely it will happen this soon.
Ma Hao
Hi Andy,
Thanks for your comment.
How is the JEMH going on?
We have used JEMH for 2 years.
we prefer to do this by our own since third party plugins always can not satisfy us 100%.
Is there any document about how to develop such feature?
January 2, 2014
Hi Ma, JEMH is going very well, new features are continuous!
When you say you want to develop this yourself, I'm confused, you already have JEMH so you could just add a custom field for email addresses, add an Event Listener Project to catch the events, identify the custom field with the email addressess and pretty much be done. What exactly do you want to develop? A starting point would of course be:
- https://developer.atlassian.com/display/JIRADEV/JIRA+Plugin+Guide
Logan Clemons
Did you ever find a good solution for this?
Nafees November 11, 2019
Good luck finding any solution!!!
Dipti Ranjan Behera
January 2, 2014
@Ma,
you can create a people role called 'comment notified users' in your project.
Associate users to whom you want to send the issue comments.
Then goto the project notification scheme , there associate above mentioned role to 'Issue commented' event.
Ma Hao
Thanks, your workaround can works for me.
But my request scenario is like:
1. End user found this JIRA issue's comment can solve some other's problem who is out of the JIRA system.
2. End user click a send via email button besides the comment,
3. End user input the mail address in the popup form
4. End user click send.
5. End user's target person will recieve the comment which format is as same as watchers notification
jing_hwa_cheok
January 1, 2014
Hi there,
I believe this is the guide you need, Creating Issue and Comments from Email.
Hope this helps!
Ma Hao
Thanks for your comment, but what i want is how to Send the Comment from JIRA to End User's mail box via email.
I know about Mail Handler which is used like catching mail to create issue.
jing_hwa_cheok
January 2, 2014
If the user is watching the issue in the JIRA, they should receive notification when you add a Comment in the JIRA issue unless the notification scheme has been change or comment is restricted.
Ma Hao
exactly, You are right.
What i want, is send the notification, as same as watchers recieved, to other person who is not watching this issue.
Like • Joe Tidey likes this
