How can i add +(create a story under feature ticket)
patel rakesh March 10, 2022
caglad
March 10, 2022
Issue types are in three levels
Epic
Story/Feature/Task/Bug/etc
Subtask
It looks like your screen resolution is off or your screen shot is cut off. But you cant add a feature under a story or vice versa - standard issue types only get a subtask. Please restate if I didnt understand your problem.
patel rakesh March 12, 2022
@caglad
TThank you for your reply. Yes I was able to understand what you mentioned through some videos on YouTube.
Once again thanks for clarification
