How can i add multiple project leads for one project
srinivasan radhakrishnan
June 13, 2013
I need two assign three project leads for on project. please give me the steps to achieve my goal in "On demand JIRA".
Nic Brough -Adaptavist-
June 13, 2013
You can't do this. Project lead is a single user.
You should, as Christian says, nominate many people in a new ROLE, but the project lead is, by definition, one person.
Christian Czaia [Decadis AG]
June 13, 2013
Why would you want to do that? Use a project role. You're far more flexible :-)
Udo Brand
June 13, 2013
Project lead can be only one JIRA-user. So use as Christian mentioned a project role e.g. Project lead deputy, add the additional persons to that role and give the role the neccessary permissions.
Sanket Sheth
July 24, 2014
The best way to achieve this is to create components. Then each component can have a lead. This is a good way to distribute the submitted items as they are then automatically assigned based on the component selected and the associated lead.
