I can't find Add category button in Setting/Project. I use my company's jira server and i'm an admin.
Hi @hauht
Welcome to the Community!!
Here's the explanation
You should be Jira Admin in order to create the Project Category
Click on the settings icon --> Projects --> Project Categories --> Create a Project Category
Pramodh
or
https://yourhostname/secure/admin/projectcategories/ViewProjectCategories!default.jspa as a quick link :)
also hitting the "gg" or "." you can just search for categories
hi @hauht , just being a project admin wont be enough, you will need Site Admin privileges to set this up as @Pramodh M has mentioned.
Cheers.
