How can i delete organizations permanently?
Stefani Kaimakliotou December 19, 2017
I have created an organization once and now i do not want it to exist. I removed all the users from that organization and want to delete it permanently from JIRA. How can i do it?
Walter Buggenhout
In the users list of your Service Desk project, select the organization so you can see the users in it.
Then, at the top right corner of your screen select the option "Delete organization":
Thank you very much.
Fer Ducloux
July 23, 2018
Why are deleted organizations still in the database?
H K
November 28, 2018 edited
I have the same problem as @Fer Ducloux.
I deleted the Organization from my project and want the same one but all ridden in capital letters.
Now I always get the suggestion for the old Organization without capital letters and I cannot create the new one!! -.-
So I had to use the old one. Thankfully I was able to rename it.. but you should be able to administer all organizations existing and be able to delete them if they are not used anywhere.
Like • Salomie likes this
Register today
