How can i export issue history from JIRA?
Archana Pandey November 20, 2014
i want to export issue history while exporting issues of a project.
Jobin Kuruvilla [Adaptavist]
November 21, 2014
Unfortunately, that is not an option. You might want to check out the plugins in marketplace that lets you write your own export templates.
3 votes
Midori
February 25, 2016
Deleted user March 9, 2020
Doesnt work on Cloud!
Levente Szabo _Midori_
Better Excel Exporter doesn't yet, but PDF Exporter works on Cloud: https://marketplace.atlassian.com/apps/5167/better-pdf-exporter-for-jira?hosting=cloud&tab=overview
Albert Kalytta March 1, 2021
When will Excel Exporter for cloud being a thing? I feel like people miss it desperately.
@Albert Kalytta *sshh* You don't have to wait too long! :) Follow this feature request to be notified of updates.
Zoryana Bohutska _SaaSJet_
March 2, 2021 edited
Hi @Carla Ann Rowland
Also, to avoid manual work, you can try Issue History add-on. It lets you get and save all changelogs.
image-2022-01-14-13-20-13-643.png Regards
You can do it using the Jira Rest API.
Check out Chris Yong's response to this post.
https://community.atlassian.com/t5/Jira-questions/Is-it-possible-to-get-the-issue-history-using-the-REST-API/qaq-p/510094
Reproducing it here for easier access:
Chris Young Nov 25, 2012
Jonny, that is fantastic. It works! Many Thanks.
jira = JIRA(options, basic_auth=(USERNAME, PASSWORD))
issue = jira.issue('FOO-100', expand='changelog')
changelog = issue.changelog
for history in changelog.histories:
    for item in history.items:
        if item.field == 'status':
            print 'Date:' + history.created + ' From:' + item.fromString + ' To:' + item.toString
Gives me:
Date:2012-10-23T09:49:41.197+0100 From:Open To:Queued
Date:2012-10-23T09:49:43.838+0100 From:Queued To:In Progress
Date:2012-10-23T09:49:45.390+0100 From:In Progress To:Blocked
Date:2012-10-29T16:06:36.733+0000 From:Blocked To:In Progress
Date:2012-10-31T16:47:40.191+0000 From:In Progress To:Peer Review
Date:2012-10-31T16:47:41.783+0000 From:Peer Review To:Customer Approval
Which is exactly what I wanted!
Now I can get data on cycle time, figure out where our bottlenecks are and see which tickets are dropping out of our workflow after we have commited to working on them.
Brilliant.
Many Thanks!
Terry Hwang
July 20, 2017 edited
Check the free plugin Issue History Printer, If you want to deep history of issues.
It was useful for me when I need to get a full change history of issues.
Doesnt work for cloud. too simplistic for what i want to do..
Carla Ann Rowland
October 29, 2020 edited
I open the issue, click on History tab and then right click and print to .pdf. It is high level and works for me.
mikko_ohtamaa
October 13, 2020
If you are looking to analyze the history, which would be the most common reason to export it, here is a nice Python/Docker tool to analyse some metrics from JIRA, by Martin Aspeli from Deloitte:
https://github.com/DeloitteDigitalUK/jira-agile-metrics
Tomasz Kustrzynski
In case anyone is interested in the solution for JIRA Cloud, there's now plugin that exports history of changes to JIRA issues - Advanced Export.
Any custom or standard field can be exported with every change as a separate row to make it easy to analyse in spreadsheet or postprocess in any other way.
Here's documentation.
Full disclosure: I'm the author
Ricardo Oliveira December 21, 2018
Hello @Tomasz Kustrzynski.
My company just downloaded the Advanced Export and We are on the free trial. I am having trouble to export Jira Issues and I did not find how to get support for you. Can you help me? Basically I am having trouble when I click on Download the Excel File I have the error: "Failed - Network Failure".
Pablo Beltran
February 25, 2016
A picture worth a thousand words...
(SQL for JIRA)
Pablo Beltran
June 24, 2015
The SQL for JIRA plugin supports it seamlessly. Simply, execute the SQL below:
select
from
     issuechanges c
where
    c.issueid=10000
it will fetch the full change history for the given issue id (10000 in the example).
Note: the SQL for JIRA plugin provides a pure JDBC driver that you can use to connect remotely to the JIRA API from any JDBC compliant tool (Birt, Jasper Reports, custom Java program, etc) and export data from there in the usual way.
vivuu
How we can customise the query for scenario given below.
We have to export the list of issues of Project ORR and Issutype RTM, which got changes last week with following information.
1) List of issues, With Issue key
2) What changes done to the field ( Before value and current value)
3) Who made the changes
4) When the changes sone)
Like • EkaterinaNazarova likes this
Register today
