I have 3 projects in on demand JIRA, 1- "Test1" , 2- "Test2", 3- "Test3".
I need to make component field as mandatory in project "Test2" only, in which way i achieve my goal?
Please share your knowledge.
Thanks.
Look at the field configuration scheme.
At the very least, you'll need to create a new "field configuration", one which says "component = mandatory". You then create a "field configuration scheme" which says "for all issue types, use my new field configuration". Then change project "Test 2" so that it uses your new scheme.
(You can do this at an issue type level - that is why it's a little complex, but I've kept it simple and looked at project only)
