×JIRA version = 8.1.0, Java Version = 1.8.0_181
I'm trying to set up a jira server on a debian machine. My first installation attempt failed to connect to mysql becuase i didn't have enough memory available.
Now i'm getting the error " Table 'jiradb.pluginstate' doesn't exist"
I've deleted the datbase and re-created it., but when i try to visit my jira installation i land on http://agile.felinesoulsystems.com:8080/jira/secure/errors.jsp which is blank.
I'm not sure how to proceed from here. How can i wipe out, and re-start the installation? I've not been asked for mysql credentials, since that first failed time.
after installing clean jira you go to the address localhost:8080 and in the web installer you will be given the choice of your own or the built-in database
Well, as indicated above, jira isn't installed on my local host. It's at http://agile.felinesoulsystems.com:8080
In fact if i leave off the /jira i get nothing. If i remove the database and restart jira, then go to the correct address i see the starting up progress bar, then i get the error.jsp page. The logs are the same, complaining about that missing table. I already set up the database, but it ran out of memory. Somewhere it's got my answers to the mysql questions stored. I need to be asked those questions again some how and start over.
How do i do that?
Ok. I deleted everything in the jira user's directory and was prompted for my mysql settings. The database test was sucessful, but after hitting 'next' i get a white screen on http://agile.felinesoulsystems.com:8080/jira/secure/SetupDatabase.jspa
I don't know what to do. My logfile is here: https://gist.github.com/b69e59a35e6ce92fbf618b4e97170214
in you log file:
MySQL 5.5.5-10.1.37-MariaDB-0+deb9u1 is not supported. You should migrate to a supported database version.
Supported versions are: 5.7, 5.6
Thank you. I'll try updating my MariaDB installation. What versions of MariaDB are supported?
MariaDB is not supported, you need to use normal MySQL
https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html
Thank you. I'll just run it with the default database for now, and bypass the mysql issue.
