×Is there a way that non-users can submit a ticket or report a bug to JIRA? Does this require an add-on?
Thanks.
Consider the new JIRA Service Desk 2.x option that allows for unlimited customers (ergo they don't count against your license).
http://blogs.atlassian.com/2014/09/introducing-jira-service-desk-2-0/
Benefits include the ability to configure a customer portal for entering "requests" in customer friendly terms, as well as their ability to see their reported issues and communicate with the support staff via comments - all on the portal!
https://confluence.atlassian.com/display/SERVICEDESK/Managing+customers
They can also receive relevant email notifications, and you can even allow ticket creation via an email channel. I recommend checking out all the options as it should meet your requirements nicely.
If you want back end integration, you just send emails to JIRA. By default you can hoover up any content sent by setting a default reporter, this is one way traffic to JIRA. If you want bi-directional involvement, you cal use JEMH to facilitate email only communication with remote users.
Andy
I have JEMH. I want to create a contact us form so external users can create issue. Instead of me creating a form, I wanted to use JIRA Issue Collector but how to integrate it with JEMH to receive an acknowledgement for the email that created an issue?
Thanks for your help.
Jaya
Somehow, you need to get information to a JIRA issue and have email addresses stored in custom fields so JEMH can drive notifications. AFAIK IssueCollector wont do that.
Writing an IssueCollector+ for JEMH has been considered but not implemented yet.
For now, you will need to create a webform that generates an email using JEMH Directives in the body (@remoteUserEmail=someemail@place.cometc) to send to JEMH to create the issue correctly, and drive notifications.
I took a look at Issue Collector. Is it just for web applications or can technically be used for anything? Thank you.
It's a Javascript snippet that can be used everywhere.
Also, is there a more customizable form? Ideally, I'd like to be able to create a form and choose various fields to display in that form. For example, "software version".
Thank you.
You could use this add on called Issue Collector. It provides you an template which you can place on your portal.
You can set up your permision scheme to allow "Anyone" to create issues (the reporter field will also have to be set not to be required). You'll end up with issues with empty reporters thoguh.
You might want to look at the Issue Collector though - it probably does what you want.
