How can we activate and deactivate a user in JIRA using groovy
SWAPNIL SRIVASTAV
How can we activate and deactivate a user in JIRA using groovy script that can be run from script console. I already have the user details which I want to activate first and then make them inactive again.
afelts July 5, 2022
@Anzaris there a cloud version of this script?
Anzar
May 10, 2022
import com.atlassian.jira.bc.user.UserService
def userManager = ComponentAccessor.userManager
def userService = ComponentAccessor.getComponent(UserService)
def active =true
    'anuser',
    'otheruser',
    // add more as required
].each { username ->
    def user = userManager.getUserByName(username)
    if (!user) {
        log.warn "Failed to find user with name ${username}"
        return
    def updatedUser = userService.newUserBuilder(user).active(active).build()
    def updateUserValidationResult = userService.validateUpdateUser(updatedUser)
    if (updateUserValidationResult.valid) {
        log.warn "Deactivating user ${username}"
        userService.updateUser(updateUserValidationResult)
    } else {
        log.warn "Update of ${user.name} failed: ${updateUserValidationResult.errorCollection.errors.entrySet().join(',')}\n"
Set the active variable to true or false for activating and deactivating respectively.
Anzar
Sreenivasaraju P
May 10, 2022
Hi @SWAPNIL SRIVASTAV ,
Please refer below documentation link.
https://library.adaptavist.com/entity/deactivate-users
