Is there a way to display the field values of linked issues on the view issue screen? I want to view a single select custom field value next to issue status under Issue Links sections. Refer attached image for more details.
Nope, not for linked issues in general but you can add a column in general settings>Advanced settings>jira.table.cols.subtasks for subtasks. ( i am assuming the linked tickets can also be created as subtasks due to the issue link type in your screenshot.)
Ok, thanks for the update @Danyal Iqbal .. this is helpful!
Can you please share detailed steps on where to find general settings?
You can find then under "Administration (Cog) > System." - is it better explained here:
https://confluence.atlassian.com/adminjiraserver/configuring-advanced-settings-938847828.html
