How can you use SQL to find the component id for an issue in the oracle tables?
Amber McCallister February 10, 2015
I see a table called component which gives me the component IDs for a project (19130). In the JIRAISSUE table there is a component column but they are all null. I need to find the link between the issue and the component table.
6 votes
Andrey Kuzmin
February 10, 2015
It's going to be something like this:
SELECT ji.issuenum, na.sink_node_id component_id
FROM   jiraissue ji
JOIN   nodeassociation na
ON     na.source_node_id = ji.id
       AND na.sink_node_entity = 'Component'
       AND na.source_node_entity = 'Issue'
WHERE  ji.project = 19130
Amihai Markovitz
June 17, 2020
I am using this tip but I still don't get the Component value, any other idea?
Bhagya M S February 6, 2018
You can use the below query to fetch the components for a particular issue in JIRA
Please specify the valid jira issue key for below query:
note: in my case jira issue key is 'TEST-171'
SELECT
(case when (LENGTH(CM.CNAME)>0) then CM.CNAME else ' ' end) AS COMPONENT
FROM JIRAISSUE JI, Project P, COMPONENT CM, NODEASSOCIATION NA  where CM.PROJECT=P.ID AND JI.PROJECT = P.ID AND NA.SOURCE_NODE_ID=JI.ID AND NA.SINK_NODE_ID=CM.ID AND P.PKEY||'-'||JI.ISSUENUM= 'TEST-171'
Nic Brough -Adaptavist-
February 10, 2015
The component column is a hangover from older ways of doing
Have a look in "nodeassociation" - I can't remember the name of the lines you need, but one column will have the JIRA issue id, and another the component id, with the third column containing something like "componentlink"
February 11, 2015
Give Andrey the points :-)
Gregory Riccardi March 18, 2020
Hey Guys this is a big help, I am looking for something a little more simple however.
I would like a list of all component names in a project.
Any ideas?
March 25, 2020
Search the component table where project = the id of the project.
Like ban yige likes this
ban yige July 22, 2021
Excuse me, does this project still exist ? I cannot find it.
July 22, 2021
What project?
July 22, 2021
I'm afraid that does not explain your question.  What project are you asking about?
Actually, what are you trying to do here?  That might be easier to tell us than explain what "project that might not exist" is
Amber McCallister February 11, 2015
Nic and Andrey,
I wanted to thank you both for all of your help with this.
Amber
