How clear attribute value ,from "Insight Automation" ?
Alex
December 14, 2023 edited
Hi, community ! I found documentation for Insight Automation, but not found how clear attribute value .
https://confluence.atlassian.com/jirakb/how-to-append-an-attribute-value-to-the-existing-values-using-insight-automation-1167746433.html
Can you help me?
Any help is important .Thank you!
Alex
April 26, 2024
I’m answering my own question: if in this place automation needs to be cleaned, then only through the rest api. In scriptrunner you can use the method to clear the attribute, update, etc. here https://docs.adaptavist.com/sr4js/latest/hapi/work-with-assets-insight
Let's build A Rovo Agent 🤖
Save your spot
