How connect to Jira server with REST API and Java language?
ROUAG Ines
February 6, 2013
I would like to use the REST API for communicate with JIRA. For example, I want to create an issue, so I must to connect to a JIRA server.
I don't know how to do. I use Java language. I search on every forums and Atlassian tutorials but it doesn't works.
I also install JRJC and Maven2 plugin for Eclipse dev cause I've seen in the Atlassian tutorial it's good to develop with this plugin but I don't know to use this plugin so when I create a Maven project I have a lot of errors. Can I have help for understand how this plugin works?
Can u help me to resolve my problem?
Thanks in advance,
Best regards.
6 votes
Timothy
February 6, 2013
You need to create a client in your Java code to send and receive REST request and responses.
https://confluence.atlassian.com/display/DOCSPRINT/The+Simplest+Possible+JIRA+REST+Examples
ROUAG Ines
February 6, 2013
Thanks for your answer!
I know this tutorial but my problem is to add depedencies in my pom.xml without errors.
Can u help me? Do you know how works Maven2 plugin?
Timothy
February 6, 2013
You'll have to find your own resources on how to use Maven 2 to add dependencies.
Just as a heads up, I use this for creating a REST client:
<dependency>
	<groupId>com.sun.jersey</groupId>
	<artifactId>jersey-client</artifactId>
	<version>1.8-atlassian-6</version>
	<scope>compile</scope>
</dependency>
I use this for parsing JSON:
<dependency>
	<groupId>com.googlecode.json-simple</groupId>
	<artifactId>json-simple</artifactId>
	<version>1.1.1</version>
</dependency>
Jonathan Hult
Register now
