Dear community,
We have a custom field "Severity" which has 'Emergency', 'Sev.1', 'Sev.2' and 'Sev.3' as options. If the value is "Emergency" We would like to automatically assign the label "Emergency_YY_WXX" to the ticket, where 'YY' and 'XX' must correspond to the year and the week numbers of the date on which the ticket was set as Emergency.
We're use to work with ScriptRunner, and I've look around a similar case but I did found a clear solution to dynamic labels.
Could you help me on this one?
Hi @Fabio Racobaldo _Catworkx_ , @Marco Brundel
Thanks for your inputs, unfortunately we do not have automation in our JIRA instance, so I could not use Marco's option.
I'm not familiar with Behaviors, I will take a look and see if I can make a script with that.
Hi @OriO ,
Behaviour is a good option. But you can also have a look at Automation for Jira.
When I set
Emergency_{{now.format("yyyy")}}_{{now.weekOfYear}}in 'comment on Issue' action I get as a result
Emergency_2022_51
Regards, Marco
Hi @OriO ,
you can implement that requirements through a Behaviour (something like https://docs.adaptavist.com/sr4js/latest/features/behaviours/behaviours-examples/setting-field-defaults)
Please let us know if you need support on that.
Fabio
