How create an issue via groovy filling a cascading field?
Rafael Costa
March 9, 2022
The code that I trying run is it:
def issueInputParameters = issueService.newIssueInputParameters().with {
    setProjectId(project.id)
    setIssueTypeId(issueType.id)
    setReporterId(loggedInUser.name)
    setSummary(summary)
    setPriorityId(priorityId)
    setComponentIds(component as Long)
    setDescription(description)
    addCustomFieldValue(data_field_id, data as String)
    addCustomFieldValue(area_solicitante_field_id, "Department -> IT")
def validationResult = issueService.validateCreate(loggedInUser, issueInputParameters)
if (validationResult.isValid()){
    def result = issueService.create(loggedInUser, validationResult)
}else{
    return validationResult.getErrorCollection()
But I give this error:
Errors: {customfield_17401=The option 'Department -> IT' is an invalid parent option}
Error Messages: []
How parse data correctly to fill this error?
Sergiienko Volodymyr December 15, 2022 edited
Hi!
For searchers like me )
To set 2nd level add ":1" to custom field Id:
def cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectsByName("Your Cascade field name")[0]
    addCustomFieldValue(cf.getId(), 'Parent value text or Id number')
    addCustomFieldValue(cf.getId() + ":1", 'Child value text or Id number')
Carlos Tichy
Hi @Rafael Costa! Create first the issue with the parent field. (Also I mean don't put the child field in the creation process). After having the issue created, then update the issue, filling the child field.
Good luck!
Carlos Tichy
May 15, 2022 edited
Hi @Rafael Costa
look at the following script excerpt, precisely that is what I say, you can create first the Issue, and after that (probably based on your conditions - selecting the child field) update then the Issue; in my case, I'm assigning it after creation (I could have done the creation with the assignment at once, but I needed to do it in two steps.):
        setReporterId(reporter.toString())
        setSummary(summary)
        addCustomFieldValue("customfield_16873", objectData.objectKey as String)
    assert validationResult.valid : validationResult.errorCollection
    assert result.valid : result.errorCollection
    def String issueKey = result.getIssue().getKey()
    def issue = issueManager.getIssueObject(issueKey)
    def userAssignee = userManager.getUserByKey(assignee.toString())
    def validateAssignResult = issueService.validateAssign(userAssignee, issue.id, issue.reporterId)
    assert validationResult.valid : validateAssignResult.errorCollection
    def resultAssign = issueService.assign(userAssignee, validateAssignResult)
    assert resultAssign.valid : validateAssignResult.errorCollection
Mohamed Benziane
Rafael Costa
March 10, 2022
The context is different, this link show how set a cascading field, but I need create an issue with the field filled.
The problem was in the child option. I could create an issue with parent option only and child as null, so I create the issue, retrieve it, then set the child option.
it was not as presented on the link, but help me to create my own script, thanks!
