Sign up Log in
How do I access the Permission Helper?
Joe Murray
https://confluence.atlassian.com/adminjiracloud/using-the-permission-helper-868982879.html suggests a way to get to a permission helper to test what the permissions are for any user. However, running JIRA Cloud version
Jira 2fc2d84d
when I get to the Permission Schemes page there is no link for Permission Helper, and searching for Helper in the browser page returns nothing. How do I access the Permission Helper to see if a report that a user can access a project that they shouldn't have access to is accurate, and that adjustments to the project have successfully removed this inappropriate access?
3 votes
patriceharapeti
April 23, 2020
  1. Navigate to the Project settings of a project.
  2. On the left hand panel, select Permissions to see the current Permission Scheme of the Project.
  3. Once viewing the permission scheme, you will find the Permission helper button positioned at the top right of the page.
Emelie
No Permission helper button at all on my screen...
SteveM
June 22, 2021
Emelie, you must be a Jira admin to use the permission helper.
Chris Jones
thanks SteveM
Wouldn't it be great if a Project Admin could use these helpers!
Like Chris Aldridge likes this
Andre Untiedt
Select a project's Project settings, see Summary page.
Select Permissions.  [Permissions helper] button is displayed top right.
Alexey Matveev
April 1, 2018
You need to open an issue, for which you want to see permissions and then run the Permission Helper from there. Kindly have a look at the screenshot:
