How do I add ActiveObject to my classpath.
Peter March 17, 2013
I just gettings started writing my first jira plugin in eclipse juno with the maven (m2) plugin installed. The plugin will need to persist and retrieve data, so I have followed as much advice and tutorials as I could find about the activeobjects plugin, but no matter what I add to my maven pom file etc., I cant get the components to load to my classpath.
As I say, I've been trying this for hours now and have had no success, so if someone could point me to the solution (I have been to all atlassian tutorials found around this one https://developer.atlassian.com/display/AO/Getting+Started+with+Active+Objects).
What am I doing wrong?
heres the meat of the pom
<dependencies>
		<dependency>
			<groupId>com.atlassian.jira</groupId>
			<artifactId>jira-api</artifactId>
			<version>${jira.version}</version>
			<scope>provided</scope>
		</dependency>
		<!-- Add dependency on jira-core if you want access to JIRA implementation
			classes as well as the sanctioned API. -->
		<!-- This is not normally recommended, but may be required eg when migrating
			a plugin originally developed against JIRA 4.x -->
		<!-- <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-core</artifactId>
			<version>${jira.version}</version> <scope>provided</scope> </dependency> -->
		<dependency>
			<groupId>junit</groupId>
			<artifactId>junit</artifactId>
			<version>4.10</version>
			<scope>test</scope>
		</dependency>
		<!-- WIRED TEST RUNNER DEPENDENCIES -->
		<dependency>
			<groupId>com.atlassian.plugins</groupId>
			<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
			<version>${plugin.testrunner.version}</version>
			<scope>test</scope>
		</dependency>
		<dependency>
			<groupId>javax.ws.rs</groupId>
			<artifactId>jsr311-api</artifactId>
			<version>1.1.1</version>
		</dependency>
		<dependency>
			<groupId>com.google.code.gson</groupId>
			<artifactId>gson</artifactId>
			<version>2.2.2-atlassian-1</version>
		</dependency>
		<dependency>
			<groupId>com.atlassian.activeobjects</groupId>
			<artifactId>activeobjects-plugin</artifactId>
			<version>${ao.version}</version>
		</dependency>
		<!-- SAL, the Active Objects plugin uses SAL's API for transactions -->
		<dependency>
			<groupId>com.atlassian.sal</groupId>
			<artifactId>sal-api</artifactId>
			<version>2.4.1</version>
		</dependency>
		<!-- Google Collections, useful utilities for manipulating collections -->
		<dependency>
			<groupId>com.google.collections</groupId>
			<artifactId>google-collections</artifactId>
			<version>1.0</version>
		</dependency>
		<!-- We're going to write a simple servlet -->
		<dependency>
			<groupId>javax.servlet</groupId>
			<artifactId>servlet-api</artifactId>
			<version>2.4</version>
		</dependency>
	</dependencies>
	<build>
		<plugins>
			<plugin>
				<groupId>com.atlassian.maven.plugins</groupId>
				<artifactId>maven-jira-plugin</artifactId>
				<version>${amps.version}</version>
				<extensions>true</extensions>
				<configuration>
					<productVersion>${jira.version}</productVersion>
					<productDataVersion>${jira.version}</productDataVersion>
				</configuration>
			</plugin>
			<plugin>
				<artifactId>maven-compiler-plugin</artifactId>
				<configuration>
					<source>1.6</source>
					<target>1.6</target>
				</configuration>
			</plugin>
		</plugins>
	</build>
	<properties>
		<jira.version>5.1.8</jira.version>
		<amps.version>4.1.5</amps.version>
		<plugin.testrunner.version>1.1</plugin.testrunner.version>
		<ao.version>0.19.7</ao.version>
	</properties>
any help appreciated.
codelab expert
March 17, 2013
There is no need to add this library manually. This library is already included in Jira!
Peter March 21, 2013
it seems it had something todo with my environment, mac osx, eclispe etc. I installed everything on a ubuntu vm and it worked pretty much out of the box.. Problem solved I guess
Register here ⬇️
