Currently using Jira Core to track workflows and would like to add a confirmation pop up before changing each status since there is room for error given how the status buttons are configured.
Example: team member approves the ticket -> clicks approve -> pop up asks "are you sure you want to approve this ticket?" -> clicks approve again.
Hi @Chegg Coop
This is easily achievable by adding a screen to your 'approve' transition. You can do this by following this KB: https://confluence.atlassian.com/jirakb/mapping-a-screen-to-a-workflow-transition-720634253.html
Thanks Daniel. Do you know if this configuration is available for JIRA Core like it is in JIRA software?
Apologies! Found the screens configuration in the settings tool. Thanks!
Thanks, but this is not correct. The link you provided shows how to add a screen to the transition, but does not provide information on how to make a "confirmation" window which, by definition, means you provide the choice of whether to proceed or cancel.
I'm not sure about the OP, but I need a true confirmation window which permits moving forward with the workflow or cancelling the proposed transition. And I still haven't found it yet...
I'm reviving @Chegg Coop and @Dave Kitabjian questions. Is it possible for displaying the confirmation window when user clicks 'approve' button?
@Chegg Coop Can you let me know where you found the Settings tool for adding a screen to 'approve' a transition? We have a status called 'PO Accepted' that used to ask for confirmation when a story was moved to that status, with the ability to add a comment. When I transitioned to a new board, that went away.
Tim
