How do I add a label in post function using scriptrunner?
Nicole Murphy March 17, 2016
I tried using both scripts on https://answers.atlassian.com/questions/307827 but neither were successful. When adding the script, the error says "cannot find matching method...". Has anyone been successful with this? Thank you!
Aleks Yenin (Polontech)
March 17, 2016
That's all about error or is there something else? Seems to be something more.
Try to debug both scripts in a script runner - works for me as well.
JamieA
March 17, 2016
The API may have changed since that answer. As Aleks said, the useful part of the error you get is in the "...".
import com.atlassian.jira.issue.label.LabelManager
def user = ComponentAccessor.jiraAuthenticationContext.getUser()
LabelManager labelManager = ComponentAccessor.getComponent(LabelManager)
def labels = labelManager.getLabels(issue.id).collect{it.getLabel()}
labels += 'new_label'
labelManager.setLabels(user,issue.id,labels.toSet(),false,false)
The error I get is:
"Static Type Checking -Cannot find matching method: com.atlassian.jira.issue.label.LabelManager#setlabels(com.atlassian.jira.user.Ap
 java.lang.Long, java.util.Set , boolean, boolean). Please check if the declared type is right and the method exists"
Like • Yash Jain likes this
The exact script I'm getting this error on is below (the code block above didn't work for some reason):
March 17, 2016
Hm... Which JIRA version do you use? Maybe it is old enough and do not have this method
Nicole Murphy March 18, 2016
6.4.6
March 18, 2016
Yes, there is difference. In JIRA 7 method signature is
setLabels(ApplicationUser remoteUser, Long issueId, Set<String> labels, boolean sendNotification, boolean causeChangeNotification)
but in 6.4.6
setLabels(com.atlassian.crowd.embedded.api.User remoteUser, Long issueId, Set<String> labels, boolean sendNotification, boolean causeChangeNotification)
Try to replace last string this way:
labelManager.setLabels(user.getDirectoryUser() ,issue.id,labels.toSet(),false,false)
that did the trick! Thank you so much!
Dan27
This code creates a "labels" , not a specific custom field with label type..
How can I set value in a custom field (with label type)
Daniel
Pratik Rawlekar May 15, 2020
@Nicole The code snippet by you above does not add new labels in the LABEL table, instead it updates the existing record in LABEL table.
Any update from your side for same?
Read the story
