How do I assign a JIRA issue to a specific user on transition?
Richard Wilkinson
I want to be able to assign an issue to our lead tester automatically on a 'resolved' transition.
Options for post-functions to add to a transition include:
* Assign to Current User
* Assign to Lead Developer
* Assign to Reporter
There isn't an "Assign to (selected user)" or "Assign to (custom role)".
The page below suggests that you can create your own post-functions, but the links explaining how to do so are broken:
https://confluence.atlassian.com/display/JIRA044/Configuring+Workflow#ConfiguringWorkflow-ApplyingPostFunctionstoTransitions
How can I set up a simple post-function to assign to the lead tester?
Obviously I could pretend the lead tester was the lead developer, and assign it like that, but I'd like to be able to specify the role properly, or select a user without a role.
Richard
5 votes
Faryaaz Kassam
go to Add new post Function->Update Issue Field->Assignee and select your lead tester.
Richard Wilkinson
Ah, OK. That should have been obvious... thanks. Since there were specific ones for the other users I thought it would be something more complicated!
Richard Wilkinson
Doing it this way assigns the issue to the lead tester regardless of whether the resolver selects a different user. Is there a way to assign the issue first to the selection of the person resolving the issue (if any) but default to the lead tester if no new user is selected? Or would a new script be needed for that?
I realise there probably isn't, since the "assign user" drop-down on the resolve screen doesn't have "no selection" - by default the current user remains selected, and I don't see a way to tell whether that's a deliberate choice or not.
I guess we would need something like, "If selected new assignee = current assignee then new assignee = lead tester, else new assignee = selected new assignee" which would involve scripting.
Faryaaz Kassam
haven't tried anything like that tbh. I would guess you'd need to script it that way.
Sharad_Agarwal
August 27, 2015
hi, I tried to follow the steps: Add new post Function->Update Issue Field->Assignee and select specific user. However, when I start typing in the user's ID, it is not recognized by the system. I tried with the ID, first name and last name. The user in question is an Admin in JIRA, and this is Cloud JIRA. Would appreciate ideas and guidance on how I could troubleshoot this. Thanks.
Benjamin Tapley
October 24, 2016
Sharad, and any others that stumble here, you need to go to System > Global Permissions > Browse users and enable this permission. Cheers!
Khanh Nguyen
May 31, 2012
Radu Dumitriu
May 31, 2012
Yet another recurrent problem of scripting the WF. You have multiple ways to achieve that:
1) using ScriptRunner - https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner - free, praise Jamie for that
2) using JJupin - https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.jjupin - created by me, but paid
3) Other plugin, check https://marketplace.atlassian.com/search?q=scripting
4) write your own postfunction, start here: https://developer.atlassian.com/display/JIRADEV/JIRA+Plugin+Tutorials
Have fun
TJ Baker
Can anyone tell me how to accomplish this task with OnDemand, or if it's even possible?
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
