How do I automatically set the Due Date of an issue via a workflow post funtion
Frank Stillone
I would like the due date of an issue to be automatically set to now() via a post function - ie, any issue created today are due today.
I believe that the way to do this is via the script runner Plugin and to run a Custom Script Post Function from the Create state but the scripts that I have found online do not work.
Can anyone help me with what script I would use to achieve this.
Community moderators have prevented the ability to post new answers.
Post a new question
3 votes
Sam Hall
January 17, 2017
Hi Frank,
There are some alternatives:
If you are sticking with ScriptRunner for JIRA, did you try the following?:
issue.setDueDate(new Timestamp((new Date()).time))
Adapted from: https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/postfunctions/set-issue-attributes.html and also: https://answers.atlassian.com/questions/32996494
Hope this helps.
Sam
Frank Stillone
Awesome - thanks Sam!
I used the first option, tested and works perfectly,
thank you
Mark Allen
Is there really no native way to do this? That's mental.
We have a cloud install, so most options here are not available, or require an add-on purchase which just feels a bit like taking a nuclear bomb to kill a mole in your back yard.
Like 6 people like this
6 votes
Richard Getz
Atlassian!!! How can you have native ability to post function estimates and time spent, but NOT due date?!?!
Nir Mazor
June 3, 2018
Interesting, should be fairly easy to implement. It's a crucial option for some issue types, like Decisions.
Like Tim McGrath likes this
Julie Ann C Manzo
December 16, 2019
is there a way for me to add automatic due dates to each tickets/story without doing some coding here? I am not a techie person and not familiar with coding. I am so basic, help me out here. Isnt supposed to be able to set automatic due dates
