How do I change fields editable/readonly with automation rules
Josef Sigl March 7, 2024
hello all,
i want to make a field "read only" if it contains a certain value example: If the issue field includes the value "A" than the field should be read only else is editable wert bestimmter wert
is this possible to do in with automation rules?
Alex Koxaras -Relational-
Hi @Josef Sigl
You can't make a field readonly with automation rules. Think automation rules as a followup action that happens after an action/event took place. On data center this could be achievable with Scriptrunner's Behaviours.
SERVER
