×Hi all,
Does anyone know how to change the order of system fields in default issue detail view? like moving status field under affect version or as screenshot showing. Thank you very much!
Best Regards,
Hi @Kris Han
You can reorder the fields from thee Request Type section.
If you click Project Settings > Request Types then choose the request you want edit.
You cannot move the Status or SLAs fields though.
Hope that helps,
Regards, Liam
