How do I connect JIRA and Confluence to SQL Server using SSL?
Charles Candale October 23, 2016
Jonas Andersson
October 23, 2016
By importing the certificate of the MSSQL server to the javakeystore, reconfigure it to the datasource SSL port and restarting the application. If you want our help, it helps us helping you if you tell us what you already tried. But yes, the short answer is YES smile
https://answers.atlassian.com/questions/143661
Charles Candale October 24, 2016
Hi Jonas.
I have done that already. I also tried various statements after the following line in my dbconfig.xml:
jdbc:jtds:sqlserver://dbserver:1433/jiradb
I have finally got this working by:
installing the Microsoft JDBC Driver 6.0 for SQL Server to the c:\Program Files folder on dbserver
ran "C:\Program Files\Atlassian\JIRA\bin\tomcat7w" //ES//JIRA081013165953
select Java tab and added the following to the Java Classpath:
;C:\Program Files\Microsoft JDBC Driver 6.0 for SQL Server\sqljdbc_6.0\enu\sqljdbc42.jar
changed the following in the C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml file:
<url>jdbc:jtds:sqlserver://dbserver:1433/jiradb</url>
<driver-class>net.sourceforge.jtds.jdbc.Driver</driver-class>
to:
<url>jdbc:sqlserver://dbserver:1433;databaseName=jiradb;encrypt=true;trustServerCertificate=true;</url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
restarted Jira
can now connect using the MS JDBC drivers and I now see encrypted connections in SQL server to jiradb
Thanks.
Charles.
Read the story
