How do I connect to SQL Server with DataQA?
Patrick McMahon November 9, 2015
How do I connect? I need to test some data in SQL Server.
Thanks.
BDQ November 9, 2015
Here is the link to the documentation: https://businessdataquality.atlassian.net/wiki/pages/viewpage.action?pageId=13697037
If you go up a level, you can see notes on all the other types too.
We do testing against SQL server, and have had most success with the jTDS driver, rather than the MS one. Please make sure that the server process has access to the driver, as per the setting in the Data Source dialog. It is fine to have it in a directory that is external to the JIRA installation.
Please let us know if you have any further questions.
