How do I connect to the Jira database inside a a Java program?
gfinesch July 31, 2018 edited
Hi everyone,
we are uprgrading soon to the lastest Jira version. For this reason we're also adapting a few Java plugins we developed for Jira 6.x.
One of those plugins required importing 3 external tables into the Jira database and I need to query them via SQL. In the current version of my plugin, I create a java.sql.Connection in this way:
    protected static Connection getDatabaseConnection() {
        try {
            GenericHelper helper = CoreFactory.getGenericDelegator().getEntityHelper("User");
            DatabaseUtil utils = new DatabaseUtil(helper.getHelperName());
            return utils.getConnection();
        } catch (SQLException e) {
            throw new DataAccessException("Unable to obtain a DB connection", e);
        } catch (GenericEntityException e) {
and then use the prepareStatement() method on what it returns. Unfortunately, CoreFactory.getGenericDelegator() is now deprecated. What replaces it? How can I achieve the same goal in another way? Any hints?
Thank you.
gfinesch August 1, 2018 edited
I eventually used
            final OfBizConnectionFactory connectionFactory = new DefaultOfBizConnectionFactory();
            return connectionFactory.getConnection();
to get a java.sql.Connection object, hopefully it works the same way
Mark Markov
July 31, 2018
Let's build A Rovo Agent 🤖
Save your spot
