I would like to create a custom select list where the values come from another field in JIRA. I want to associate records without using the link issue functionality.
For example:
1. I create a story record.
2. I create a test case record and within that record/page I want to have a dropdown where I select the story associated to the test case. The values in the dropdown would come from the list of story records I have entered for the project. Is this possible without creating a custom plugin?
You can use the nFeed plugin to get the data for a custom field from the Jira database.
Henning
Thanks Henning. I was hoping for something within the tool, I don't think JIRA will do what I want without spending more money, but thanks for the assistance!
Can you explain why you don't want to use issue links? It seems you are trying to do just that - linking a test case with a story.
