How do I create a default entry for the description field specific to a project?
Inayat Nahvi
This worked in JIRA 4.1.1, but not after upgrading to JIRA 5.2.10. In 4.1.1, I would go to the field configuration of a specific project. Within it, I would go to the Description field, click on edit, and type my java script. Then, whenever a new issue is created in this specific project, a default text would appear within the description box.
However, this is no longer working in JIRA 5.2.10. Any suggestions? Keep in mind, I want the description field to be populated with default text only for a particular project, not all projects. Thanks.
Ubisoft
December 23, 2013
He need it in the specific project so it need to be in the field configuration of all the issue type wanted for that project, its easier that way.
RambanamP
December 23, 2013
yes i know that, we need to add condition, that can be done!!
Ubisoft
December 22, 2013
Hello, in your specific field configuration just put this and it will work with jira 5.2
<script type="text/javascript">
AJS.$("#description").val("default value");
</script>
Inayat Nahvi
Thanks. This works exactly like I need it to.
Vera Henrichs
June 6, 2016
Hi, this sounds like something I need too.
I have JIRA 6.4.12.
I don't understand what to do with that piece of code. Can you help me?
Gebsun
November 19, 2014
Hi guys,
There is Default Values plugin available for JIRA. It allows to define default value for description and number of other fields (per project and issue type):
https://marketplace.atlassian.com/plugins/com.gebsun.plugins.jira.defaultvalues
Gebsun
RambanamP
December 22, 2013
try with this script by adding it in announcement banner for testing purpose
function addDefaultValue() {
//need to add condition here
AJS.$("#description").val("default value"); } (function($) { AJS.toInit(function(){ // init on load addDefaultValue() }); JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) { // init on refresh addDefaultValue() }); })(AJS.$); </script>
i suggest to load it as webresource module in plugin, check this
https://answers.atlassian.com/questions/47843/strange-javascript-problem-in-create-screen
Learn more
