How do I create a jira-config.properties file?
Adam Grace
Hi all,
I'm trying to use a solution to a previous ticket solution and have found that my JIRA directory doesn't have a jira-config.properties file.
I've search but have come up short.
Any help is appreciated!
Adam
Tam Nguyen
March 12, 2012
Hi Adam,
If jira-config.properties doesn't exist you can create it as a text file then add your customized properties.
Adam Grace
Fantastic. Sorted!
Thank you
Steve Adey
In what folder?
Rodrigo Cortez
June 18, 2019 edited
jira-config.properties must reside in Jira Application home directory.
Rodrigo Cortez
June 18, 2019
Please take a look on "How to edit the jira-config.properties file" document for full details on that matter.
Vidder Jira Administrator March 18, 2013
Hi Adam or Tam -
Could you send me a sample file?
Register here ⬇️
