Hi Team,
I have created category and under the category i have added some project this category shows project name only.
But I'd like to create some group for some perticular projects and export in any formate. e.g. i have 3 groups and each group contain 5 projects and i want to group1 project details then i am open that group its shows project name , project key, project tye, project admin and according to requirement i am able to export it as excel/PDF/World/XML.
I am using JIRA version: 7.0.3
Please suggest.
You can implement this custom report (like pretty much anything else that is generated from JIRA data) using these add-ons:
You need to write a short Groovy script that loads all projects from ProjectManager and builds a category-to-projects multimap from those, then transform this to Excel or PDF. This is fairly trivial.
