How do I delete a field configuration scheme via scriptrunner?
KD November 2, 2022
Quite simple what I'm trying to do, I have an array of field configuration schemes (projectlessFieldConfigSchemes) that I would like to delete. I attempt the code below to remove just the first of the array.
def fieldConfigSchemeMgr = ComponentAccessor.getFieldConfigSchemeManager()
def temp= projectlessFieldConfigSchemes[0] as FieldConfigurationScheme
fieldConfigSchemeMgr.removeFieldConfigScheme(temp.id)
The error I am getting is such:
java.lang.NullPointerException at com.atlassian.jira.issue.context.persistence.FieldConfigContextPersisterWorker.removeContextsForConfigScheme(FieldConfigContextPersisterWorker.java:90) at com.atlassian.jira.issue.context.persistence.CachingFieldConfigContextPersister.removeContextsForConfigScheme(CachingFieldConfigContextPersister.java:127) at com.atlassian.jira.issue.fields.config.manager.FieldConfigSchemeManagerImpl.removeFieldConfigScheme(FieldConfigSchemeManagerImpl.java:236) at DeleteInactiveFieldConfigSchemes.run(DeleteInactiveFieldConfigSchemes.groovy:35)
I also tried using the FieldLayoutManager instead and here is the code and error.
Code:
fieldLayoutManager.deleteFieldLayoutScheme(temp)
Error:
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.fields.layout.field.DefaultFieldLayoutManager.deleteFieldLayoutScheme() is applicable for argument types: (com.atlassian.jira.issue.fields.layout.field.enterprise.ImmutableFieldConfigurationScheme) values: [com.atlassian.jira.issue.fields.layout.field.enterprise.ImmutableFieldConfigurationScheme@#############]
Volodymyr April 1, 2024
Script for deleting not used Field Configuration Schemes and Field Configurations. Please use responsibly:
def html = ''
def flm = ComponentAccessor.getFieldLayoutManager()
// Field Configuration Schemes without projects  - can be deleted
def schemesToDelete = flm.getFieldLayoutSchemes().findAll{!it.getProjectsUsing()}
html +="Field Configuration Schemes for deletion(count:${schemesToDelete.size()}):"+schemesToDelete*.name+'<br>'
//delete not used schemes
schemesToDelete.each{ scheme ->
   // flm.removeFieldLayoutScheme(scheme)
   html += "Scheme: ${scheme.name} was deleted<br>"
// part 2: deletion of Field Configurations
def layouts = flm.getEditableFieldLayouts()
// Field Configurations without Field Configuration Schemes - can be deleted
def fieldConfigurationsToDelete = layouts.findAll{!flm.getFieldConfigurationSchemes(it)}
html +="Field Configurations for deletion(count:${fieldConfigurationsToDelete.size()}):"+fieldConfigurationsToDelete*.name+'<br>'
//delete not used Field Configurations
fieldConfigurationsToDelete.each{ config ->
    //flm.deleteFieldLayout(config)
    html += "Config: ${config.name} was deleted<br>"
return html
Jeremy Jedlicka
June 15, 2023 edited
This was a very confusing thread to follow. For anyone seeing this in the future here is the code to delete a set of field configurations by their ID.
def fieldConfigSchemeMgr = ComponentAccessor.fieldLayoutManager
def layouts = []
for (l in layouts) {
def layout = fieldConfigSchemeMgr.getFieldLayout(l)
fieldConfigSchemeMgr.deleteFieldLayout(layout)
Stephanie Bryant August 4, 2023
Jeremy,
Thanks for this code snippet! Is this to delete a field configuration scheme, or just the field configuration/layout?
Volodymyr April 1, 2024 edited
Discussion helped me to write script for deleting not used Field Configuration Schemes and Field Configurations. Adding as a separate answer
KD November 7, 2022
You can delete the schemes in this way.
def fieldLayoutManager = ComponentAccessor.getFieldLayoutManager()
def temp = fieldLayoutManager.getFieldLayoutSchemes()
fieldLayoutManager.removeFieldLayoutScheme(temp[1])
Anyone looking should be able to extrapolate what they need into an if and then an each. Best of luck to anyone trying to understand the difference between
fieldConfigSchemeMgr.getFieldConfigScheme(x)
and
fieldLayoutManager.getFieldConfigurationScheme(x). Unfortunately, that answer was not found in this discussion.
Michael Aglas
fieldConfigSchemeMgr.getFieldConfigScheme will get you the issuetype scheme, while the other gets you the field configuration scheme -> don't know why the naming is so weird in the API
Nic Brough -Adaptavist-
November 2, 2022
Immutable objects do not have function calls that change them, so your second try is always going to fail.
In your fist bit of code, I don't think your temp object contains anything.
KD November 2, 2022
Thank you for your interest. So the first bit of code is referring to an array of Field Configuration Schemes that I gathered via the command
fieldConfigMgr.getFieldConfigurationSchemes(fieldLayout)
So I can with certainty say that there are Field Configuration Schemes in the array. You're right that it's Immutable, but I'm not sure how to call or if it is possible to call a mutable field config scheme to make the second code set work ever.
It's probably important to note that this code is being run via the scriptrunner console.
November 2, 2022
But you're not putting anything into the "temp" variable, unless you've not given us all the code.
KD November 3, 2022 edited
I did not, just put in the lines that led to the error since the full code is quite long and unnecessary. I have gone ahead and simplified the code with the error to be self-contained. FCS 13300 exists. I am certain there is something small I am missing, but can't find any working examples online either.
def fieldConfigSchemeMgr = ComponentAccessor.fieldConfigSchemeManager
fieldConfigSchemeMgr.removeFieldConfigScheme(13300)
KD November 3, 2022
Very interesting development this:
fieldConfigSchemeMgr.getFieldConfigScheme(13300)
Returns null! So you're definitely onto something of me grabbing nothing. But get this, if I grab it like this:
fieldLayoutManager.getFieldConfigurationScheme(13300)
I get the scheme I'm looking for. Why is it not finding this?
I looked at the groovy documentation and removeFieldConfigScheme(Long fieldConfigSchemeId) vs getFieldConfigurationScheme(Long schemeId)
What would the difference be in fieldConfigSchemeId and schemeId? Maybe this base misunderstanding is the root of my issue?
KD November 3, 2022
getFieldConfigScheme() returns issue type schemes! Why?! Groovy, why.
KD November 3, 2022
I still would love some insight into this as you would think that the method "getFieldConfigScheme" would return a Field Config Scheme, but I have gotten the code to work with
But please still please point me in the direction of any good documentation on this because I was not able to find any and would truly like to understand the "why" behind this.
November 3, 2022
I am very confused by your postings of partial bits of code, so I am not sure what you would like a pointer to.
But I suspect it would be a part of https://docs.atlassian.com/software/jira/docs/api/9.3.1/
KD November 7, 2022
Nope, that's the documentation I referred to earlier that was not great, but I have answered the based question for myself and posted the code for others, so I'll go ahead and close the question.
