How do I disable a user using jira command line interface?
Sorin Sbarnea (Citrix)
September 11, 2012
How do I disable a jira user using the command line interface?
Bob Swift
September 11, 2012
Currently not supported. The remote APIs in this area are lacking, so it more difficult to provide the support. Please create an issue
September 11, 2012
Geoff
May 5, 2014
It looks like this functionality has been added since this question was asked. Adding the reference here for those searching for it:
jira --action updateUser --userId "testuser1" --userFullName "Former employee" --deactivate
Taken from https://bobswift.atlassian.net/wiki/display/JCLI/Examples
Ron Winacott
September 11, 2012
One way you could try is remove the user from all groups, including the magic group jira_user. Now there account is disabled and not counted in your license
CLI command removeUserFromGroup parameters userId, group
September 11, 2012
No, I'm not looking for the old and sick way of disabling users, the way that prevents you from reenabling them because you don't know which groups they used to be belong to.
I am looking for using the "Active" option which was added to Jira 5.1
