×Hi guys, I'm currently in the processing of auditing my Jira database and would like to export the Users and Roles page for each of my current active projects.
Is there a feature I can use to do this? I've tried to see if there is an export available but am not finding anything useful.
Any help is hugely appreciated.
Many thanks,
Karan
@Karan Ponnuthurai @Joseph Hani
One way that wasn't mentioned yet is the User export feature of Better Excel Exporter. With a single click, it exports your users, their statuses (inactive/active), last login, roles and many more attributes:
Hello @Levente Szabo _Midori_ ,
I will take a look at this App, it can be really useful if it can also export all user and tell us in which AD group he is and in which project he is.
Do you know if it can give the size of a project ? For example i'm looking for the total size of attachment in each project.
I'm trying to code this but I know it would work only 1 project at a time.
Thanks you for your help !
JH
Yes, it looks possible for a first glance by customizing the script behind the export template. You can find the documentation for customizing Excel reports here. Feel free to start a trial and open a support ticket with our technical support team if you have questions, they are ready to give you pointers.
Hi Levente, this is exactly what I need. We also have Better Excel, but can't seem to pull in Project Roles
Leanne
Have a similar task. Main part:
What kind of information related to users and roles do you want to export?
There are some export options.
If you are looking for active users, active projects, user login information, where users are referred in issues, permissions or something similar on these lines then I would say ScriptRunner for Jira can be used to achieve this. For instance this script will give you list of inactive users, this is of course one example but there are lot of possibilities when you use ScriptRunner for Jira.
I hope it helps.
Ravi
Hi @Ravi Sagar _Sparxsys_ , thanks for getting back so promptly.
I'd essentially like to export the information in below pages such as in the screenshot below. The very minimum I would require is the name of the user/group and which role has been assigned.
If there's a plugin within JIRA that can be used that would be perfect, but if not, that's perfectly fine as well.
Karan
Also, I have made couple of videos on this topic.
I hope it helps.
Ravi
Hey @Karan Ponnuthurai ,
Sorry to update your request, have you find any way to do it ? I have the exact same request :)
I have found this solution, but maybe you have find another way, better one.
Let me know,
JH
