How do I find the Jira installation directory?
eiger3970
I installed Jira and need to copy the MySQL JDBC driver to my application server.
I find my root /lib directory, however I'm unclear where the <Jira installation directory>/lib/ directory is?
I looked in /home/jira, but there's no directories there?
I'm following step 2.2: https://confluence.atlassian.com/adminjiraserver/connecting-jira-applications-to-mysql-938846854.html
Nic Brough -Adaptavist-
September 23, 2018
<jira installation> is where-ever you installed the system.  We can't tell you where you told it to install!
If it's running though, just look at the system information page under the admin section, it will tell you <jira install> amongst other things.
eiger3970
